Couple questions regarding lift and plastic repair
jesus_man
I want to lift my pop-up to make it more off-road friendly. I have torsion axles. I assume that there is no way to just re-clock the torsion arm to gain lift? I also assume this could be a bad idea in the event that you are backing up against a rock or something and the axle might try to rotate forward under the trailer.
So it seems that most people simply cut off the stock stuff and add in their own lifting blocks and side plates. Anyone have pictures of their home-brew stuff for a few ideas?
Also, I have a crack from front to back on the plastic cap to my front storage box. What's a good way to fix this and make it weather-proof again? Thanks!
J.D.
zhukoveli
