Crank pulley wobble- 95 Montero SR
CaptSlower
Tore my alt/fan belt pulling into the driveway last night after work. During replacement I noticed some crank pulley wobble? I assume this is abnormal? Is it a bearing issue? What will I need to do to fix it?
Thanks
UK4X4
yes you have to replacethe tension pully wheel
- thats the reason your belt is trashed,
check all of them for looseness
CaptSlower
We're talking about the timing belt tensioner pulley? Also perhaps harmonic balancer and crank pulley? How can I tell if there is further damage?
Toasty
Sounds like you've got the old crank bolt, there is a few write ups on 4x4wire.com on how to fix this. fix it now or it will be a very expensive repair.
