CRD Suspension Vs Heavy Suspension
jeepmedic46
Going with the OME lift in the spring. Question I have is further down the road I would like to convert my 3.7 to a CRD diesel. Should I go with the suspension that will handle the diesel? :smiley_drive:
LilKJ
If you wheel yours enough... your current setup should be nice and due for replacement by the time the CRD swap comes around:victory:
The CRD OME stuff will beat the poo out of you most likely...but I haven't ridden in a gasser that has it.
jeepmedic46
I'm hoping to replace my suspension in the spring. I have the current suspension on it now. Hoping to bring it up enought to put 265/70/16 m/ts on it. Hoping to put the diesel in the following year. Not sure if I want to buy 2 new suspensions.
tommudd
With the OME CRD springs it will be a rougher ride with nothing else up there. Now if you currently had a ARB and winch for example it would be OK with the extra weight = rougher ride until that time.
I have rode in both
Goldenbora
