Cummins repowered 1979 Dodge W200 4 door
jensenkennels
Unfinished resto-mod. 80% complete. The listing below states what is included in the sale.
-1992 CTD front clip
-1992 CTD front doors
-Frame has been squared, boxed, jig holes filled
-Steering gear mount reinforced
-JCWhitney weatherstrip kit
-Energy Suspension cab mounts
-Custom made inner fender liners
Front Axle
-ARB RD21 airlocker
-4.88 r&p
-8' braided ARB airline
-new bearings and seals
-new brakes
-braided caliper lines
-Lube Locker gasket
-Kryptonite diff. cover
-NWFabworks High Steer
-ARP stud kit
-1410 straps
Rear Axle
-ARB RD35 airlocker
-4.88 r&p
-20' braided ARB airline
-new brakes
-Lube Locker gasket
-1410 straps
-Missouri Offroad Axle Truss
-Rear brake disc conversion - not installed
Motor - 1992 CTD 130,000 miles
-Killer dowel pin killed
-New front main seal
-New rear main seal
-New valve cover gaskets
-Valves adjusted
-2nd Gen. low pressure lift pump
-Bully Dog fuel pin
-New HX35 Turbo
-4" ceramic coated downpipe
-Horton 2nd Gen. Fan
Transmission - 1992 A518
-2nd Gen. flexplate
-TCI Torque converter
-Hughes Performance shift kit
Fuel tanks
-2- 34 gallon Ramcharger tanks
-3/8" pickups
-Pollak Motorized Fuel Tank Selector Valve
-Jaz Fuel Cell fill
Transfer Cases
-NP205 out of '92 CTD, shift rails Machined for triple stick
-NP203 out of '79 W200
-Both new seals
-PolyBushing transfer case mounts
-billows vent
-NWFabworks - Billet kit
- 32 spline input gear
- doubler kit
- side mount kit
-Air cylinder shift components
Front Driveline
-High Angle Long slip 3" tube
-1410 ujoints with straps
Rear Driveline - 1992 CTD
-High Angle E-Brake
-balanced
-new carrier bearing
Steering
-Borgeson Steering Shaft
-West Texas Offroad Hydro Assist
-tapped steering gear
-Sauer/Danfoos Power Steering Pump with Stirling Relief Valve
Rims
-Stazworks Double Beadlocks 17x11
-Powertank Monster Valves
-DynaBead Valve Stems
Seats
-PRP Daily Drivers Xtra wide
- lumbar support
- sliders
-Crow V-Harness with pads
Suspension
Front
-SkyJacker D600S 4" leaf springs
-SkyJacker DA60 Extreme shocks
-Energy Suspension bushings
-5/8" greasable bolt
-2" shackle extension
-1 1/2" front spring frame bushing upgrade
-ubolts flipped
-grade 8 bolts, nut, washers
-Timbren A170-55 with cans
Rear
-SkyJacker DR40S 4" leaf springs
-SkyJacker DA40 Extreme shocks
-4"shackle flip
-ubolts flipped
-Timbren A535-55 with cans
Misc.-
-Vanco Hydroboost
-Haldex air compressor with relief valve
-Grade 8 Fasteners throughout
-Tuffy Series 2 Security Console with armrest and rear drink holder
-One off front bumper with 7.5 gallon air tank
-One off rock sliders
-One off roof rack
-One off tubed bed
-One off skid plates
-One off rear bumper
-One off cage and dash
-One off crossmembers for transmission and transfer cases
-One off dual battery box
-Conversion van rear folddown seat
-4 LightForce Blitz lights
-4 LightForce Stryker Lights
-TMax 12000 winch
Second Skin Audio soundproofing material
-3 Shop Pack Damplifier Pro
-10 sheets Luxury Liner Pro
-2 gallons Sprayable Spectrum Vibration Polymer
-3 Second Skin Contact Spray Adhesive
-1 undercoat spray gun
-150' roll foil insulation tape
-2 wooden hand rollers
This project is 80% complete. A minimum of the following needs to be addressed-
-Fuel and brake plumbing.
-Wiring
-Gauges
-Tires
-HVAC (if you want it)
This project is undrivable and must be trailered.
That's a helluva list and I'm certain I've forgotten something.
shortbus4x4
Can't believe you still have this. I think I saw it on Pirate a while ago. Wish I had the money because its a heck of a deal. You are close enough to me I could make the trip in a weekend and taxes are coming up, hmmm. Was the bare metal painted and has it been parked outside?
jensenkennels
All the bare steel, minus the rocksliders which are primered, has been powdercoated, painted or Scorpion Liners. It is parked inside.
Xfactor
Absolutely stunning truck! love the concept, and the design thus far. is the interior complete? Are you a shop, or a hobbyist? fantastic work!
flipstick
