tylerm1123
Designed and built with the following elements in mind:
Ability to be lived in full time if desired
Truck and camper combination allow for living space and truck to be used together or separate (which means you have a fully functional work truck!)
4 wheel drive to access all the far out there places
Functional and stylish design features make it feel like a home, not an RV
Can run Biodiesel or WVO
Can get 22 MPG!
Average around 18-20 MPG.
Asking 25k, open to offers.
Read on for all the tech specs and nerdy details!
The Truck:
1996 Ford F-250 HD
7.3L Diesel
150,xxx Original Miles
Clean Title
4x4
Automatic Transmission W/OD
Cruise Control
TS 6 Position Chip (uninstalled)
Warn Manual Locking Hubs
BF Goodrich KO/2 AT M-S + Ice Tires (like new w/ warranty)
Power Locks
Power Windows
Dual Fuel Tanks
Ice Cold AC
Strong Heater
Running Boards
Extended Cabin (seats six)
Long Bed
10,000 lb Class IV Tow Hitch Receiver
Triple Ball Hitch (1 7/8”, 2”, 2 5/16”)
Locking Hitch Pin
Tekonsha Voyager Brake Controller
200 watt LED light bar
Carhartt Seat Covers On All Seats (upholstery is perfect underneath)
Upgraded JVC Deck with Bluetooth, Handsfree, and CD player
Upgraded JVC Speakers; Front and Rear W/ Integrated Tweeters
Snow Chains
Recovery / Tow Strap
Jumper Cables
Purchased the truck Jan 2017
Upgraded 6637 Air Filter
New Vacuum Pump 2017
New Alternator 2017
New Water Pump 2017
Front Brakes / Rotors 2018
The Camper:
Built in the spring of 2018
Rare Sunrader Fiberglass Cabover Camper Shell W/ Raisable Rear Door
Entire Fiberglass Shell Sanded / Patched / Painted
Wood Sub Frame
Walls / Roof / Floor / Under Bed Insulated W/ Reflectix Bubble Insulation (R4) Then 2” Reflective Foam Core Board (R10) Then Siding / Floorboards / Plywood
Marine Grade Plywood Lower “Bucket”
Custom Made Blackout / Insulated Curtains
2 - 48” x 20” Sliding Glass Windows W/ Screens
Maple Hardwood Floors
Aeromatic Western Cedar Siding
Birch Butcher Block Countertops
Maple Kitchen Cabinets W/ Locking Hardware
Stainless Steel Sink / Tap W/ Automatic Pump
7 Stage Reverse Osmosis Filter W/ Separate Tap
3” Birch Butcher Block Backsplash
Camp Chef Aluminum Dual Burner 40,000 BTU “Mountaineer” Stove
High Efficiency Whynter 62 Quart Dual Zone Fridge / Freezer
Maxxair Fan 7500k 10 Speed, Thermostatic Controlled, Intake / Exhaust, Powered Opening
48” Plexiglass Skylight Around Fan
Camco Olympian Wave 3 Catalytic Safety Heater 3,000 BTU
Stowable Birch Butcher Block Table
5 Gallon Propane Tank
30 Gallon Fresh Water Tank W/ Fill On Side Of Camper
5 Gallon “Grey” Water Tank W/ Drain Tube
5” Memory Foam Mattress
Power
3 x 100w Renology Solar Panels (300 watts total)
2000w Continuous / 4000w Peak Pure Sine Wave Inverter
300 AH Liquid Gel Deep Cycle Batteries
30A Solar Charge Controller
2 x 110v GFI Protected Outlets Hard Wired To Inverter
6 Recessed LED lights W/ Dimmer
12 Terminal Fuse Panel
HappiJac Frame Mount Tie Down System W/ Stabilizer Bar
HappiJac Turnbuckles
2 Slide Under Jacks To Remove Camper (not pictured)
The entire camper is self-contained and is fully operational without the truck. Willing to sell camper separately but will not sell just the truck.
Dimensions
Floor to Ceiling 70.5”
Bed 67” x 60” (Short Queen)
Total height: ~10’ Tall
Email
Tylermarch@me.com
Can get 22 MPG!
The Truck:
1996 Ford F-250 HD
7.3L Diesel
Clean Title
4x4
Cruise Control
Power Locks
Power Windows
Dual Fuel Tanks
Ice Cold AC
Strong Heater
Running Boards
Long Bed
Locking Hitch Pin
Snow Chains
Jumper Cables
New Alternator 2017
New Water Pump 2017
The Camper:
Wood Sub Frame
Power
Dimensions
Tylermarch@me.com
