coppertop_01
Crazy Ginger
This design has gone through 4 different setups, started life as a battery and a loose power inverter, second year installed all of it and a second battery into a red tool box, had some problems with my 250w inverter so in the third year it was replaced with a 1000w inverter......barely got used, broke my leg in the summer that put me on the sidelines for 6 months. Went to clean, repair and charge it up and it was on its last legs, both batteries were gone and the tool box had so much corrosion that the bottom of the steel was so thin I didn't think it would support the batteries. So last Sunday I took all the pieces to work (including newish batteries) and built a new, better, stronger and shiny new box.
Case, 16ga stainless steel welded and polished, double lip and weather stripping for water protection, handles also double as vents for the inverter, wiring and orerhangs to protect against water intrusion, stainless piano hinge with a nice little locking catch (not pictured, I installed and finished the wiring after the pics were taken)
All in all, spent 5-6 hours to design, program, laser, form, weld, polish, install parts and wire......that is a good day
Jer
Jer
