Custom built trailer - set up for long distance travel.
Mike S
Sponsor - AutoHomeUSA
Selling my OR trailer. This trailer was built by Wayne Percival about 5 years ago. Along with the trailer, the buyer will receive a 10% discount on any AutoHome tent in stock.
Here are some specs/features...
- Frame is 1/4" wall, 2" square steel tubing - powder coated black
- Swiveling pintle lunette
- Extendable tongue goes out to 5' long
- Spare tire carrier to fit 6 on 5.5" rim with 31" tire
- Delta tongue box with two nesting aluminum tool boxes
- Dual 105 AH marine lead acid batteries with marine quality battery frames and hold downs - Mounted in tongue box
- Guest Marine 2 bank 10 amp charger with external plug in side of the tongue box
- 12 V outlet in side of tongue box
- 1.6 GPM Shurflow water pump plumbed to spigot on side of tongue box (operates on demand - ON/OFF is a protected toggle inside tongue box)
- Lid is aluminum powder coated white, with continuous, heavy duty stainless hinge at the front
- Lid fitted with Yakma Landing Pads to carry gutter mount towers and cross bars
- Tail gate (48" X 27") opens independent of the lid
- Box is 48-1/2" wide on floor, 72" long, sides are 27" high
- Fuel can carriers with four 5 gallon Blitz fuel cans - carries 20 gallons of extra fuel
- Water proof tail lights match Land Cruiser - two red, two yellow, plus license plate light.
- Seven pin connector
- 38 Gallon water tank between the frame rails and rear of the axle - 3/8" welded ploy with 1/8" thick powder coated steel skid plate. Stainless filler pipe at rear PS.
- Axle is 3500 lb. HD that is the same hub-to-hub measurement as an FJ60 and has 6 on 5.5" hubs. Leaf springs and sprung over - 12" ground clearance
- One rod in the rear PS latch is damaged - needs to be re-threaded (latch part is in the tool tray in tongue box)
- Spare tire included
- California permanent trailer registration - plates are current
- Wheel chocks, water proof axles grease, water filler hose and cable lock in the tool box
Trailer is has a red box, white lid, black frame - all powder coated. Good condition, every thing works, tows extremely well empty or loaded. Trailer usually weighs 1000 to 1200 lbs. LOADED. Pictures to come.
Price is $5000. This is about 50% of replacement cost.
Available for viewing at Mudrak Custom Cruisers in Sonoma, CA. 707-292-3509
Or call me at AutoHome - 888-852-2359
spressomon
Mike: Is your Air Stream ready and completed? I assume the AS will be your trailer of choice here on out?
Mike S
Dan:
My Airstream is fully functional, and is really a portable hunting lodge. I plan a series of 'improvements' that will take a year or two to complete.
The OR trailer is about 5 years old, and is not pristine enough for use at shows and exhibitions. I am in the planning stages of a new trailer to replace it. Dunno which way I will go yet.
An OR trailer has advantages - significant ones - as you know. The Airstream also offers advantages... particularly when I am in Montana or Oregon for weeks at a time with the dogs.
02TahoeMD
Boy, that is tempting. A shame it is on the wrong side of the country from me! Good luck on the sale.
Mike S
Will deliver
I will deliver anywhere in Northern Cal or NW Nevada. Or meet you part way.
Thanks.
Mike S
One more bump. Have buyers but no money yet.
I prefer not to sell this on Craig's List.
Mike
sacto_patrol
Do you any photos from further out showing the entirety of the trailer?
Also is the wood camp box included?
Thank you for your time.
Jon
Schattenjager
I too am interested in a trailer - having a very hard time seeing how a new off road trailer is worth $8K with no motor... but I am willing to learn.
More pictures would be helpful
Houie
