Schmitty21
Selling my custom made rack made from channeled aluminum. Rack is all bolt together and completely customize-able with parts from 80/20 or similar companies that sell this stuff. I've taken it over a lot of gnarly washboard and not one bolt came loose, everything is lock tighted. Holds way more weight then you could ever put on it.
Comes with a Hi-lift jack mount on the side and two Quick Fist clamps on the back for a shovel or other tool. Plenty of other gear can be mounted anywhere due to the channeled design.
The rack itself is about 63" square. The bolt holes for the legs are 68" apart and I use angle aluminum plates to bolt it onto my bed. You could either mount through the leg holes or do like I did and fab up your own plates to fit your bed. This rack was built for a 2006 F150 but can be made to fit pretty much any truck with a similar bed size, think any full size truck.
The design uses 80x40 double channel on 3 sides and then 40x40 single channel on one side to allow for tent opening. I fit a Tepui Kukenam 3 person tent and a mountain bike rack on top. Any tent with a packed size of less than 60" width and length will fit.
Rack is located in Spokane, WA. I'd rather not ship it as it weighs about 90lbs.
Asking price is $1,000. Local pickup.
