Chandlek70
Get Ready for Spring and Summer. This trailer will follow you on all your adventures!
This multi-purpose trailer, built by Expedition Supply Trailers (https://www.facebook.com/expeditionbuilt) is light in weight but super sturdy and designed for off-road use. Don't go for a teardrop trailer which won't make it offroad! This guy will follow you anywhere.
Asking $19,500.
Use it as a base camp for your outdoor adventures, haul your toys and camp off the grid or tow for a an overland adventure. The base is a new M1101 military trailer and the top is custom fabricated for storage, gear hauling, sleeping or whatever mode you'd like. It's got a ton of custom features:
- HIT Expedition Grade Rincon tent (https://www.hitents.com/roof-top-tents)
- Custom Aluminum rooftop rack with a Frontrunner t-slot rack section for mounting various accessories
- Frontrunner 17.7 gallon water tank, mounted on top with gravity flow
- Max Coupler articulating hitch made for offroad use to provide a greater range of motion between tow vehicle and trailer
- Icon Six Speed 17" wheels mounted with brand new Nitto Terra Grappler tires
- Suspension upgraded to Timbren axleless suspension for improved ground clearance and smooth towing
- Double propane tanks to power the kitchen stove or an outdoor portable firepit
- Full pantry shelf system to keep your outdoor kitchen organized
- 12v electrical system wired to a Switch Pro control module to power exterior Baja Designs Squadron lights, interior work lights, exhaust fan, USB ports and voltage guage.
- NOCO dual battery charger for use with solar or shore power
- Gear storage designed to accommodate ALU-BOX ABS 29 storage containers
- 2 Aluminum tables designed to quickly attached to trailer body for food or gear prep
- Alu-Cab 270 degree Shadow awning for sun and rain protection over the kitchen area
- All doors of trailer can be securely locked
- Electric brakes, trailer lights, etc. all operate off standard 7 pin harness
Kids going to college and it's time to make room in the garage.
[/QUOTE]
Renew post
Asking $19,500.
[/QUOTE]
Renew post
