Custom Toyota & Four Wheel Camper FS
kcowyo
ExPo Original
Passing this along for good guy. A one of a kind outfit....
Link to original For Sale Ad - <--- click here!
FOR SALE Sold as a matched pair. Built to go anywhere you want to go, even with the kitchen sink. Perfect for outdoor enthusiasts who want to travel rugged roads and camp off-the-beaten-trail.
1983 TOYOTA 4X4 LONG BED CUSTOM PICKUP
LIGHTWEIGHT 2001 FOUR WHEEL POP-UP CAMPER, RANGER MODEL
1983 Toyota Pickup Four wheel crawler and highway cruiser
Engine
Professional built Chevy V-8 small block 400 Stroked (6.7 Liter) with only 14K miles. Rods are longer than stock at 6-inch length. Edelbrock Pro-Flow Multi-Port Sequential Fuel Injection has keypad in cab for adjustments on the fly. Trick Flo aluminum cylinder heads. Custom Erson cam shaft. Roller lifters and roller rocker arms. Evans waterless NPG+ coolant with total bypass thermostat. Power Steering. Air Conditioning. R & M heat exchanger hot water shower system. Premier Power welder and power supply with 160 AMP alternator. Tilton High Torque Starter … . Engine temperature runs cool.
Transmission and running gear
NV-4500 5-speed manual transmission with 0.75 overdrive and 5.61:1 first gear. Dual Toyota transfer cases with two shifters, front input shaft heavier 23 splined for torque. J. P. Eater adapter and 2.28:1 gears front case, 4.1:1 gears rear case. Final crawl ratio is 215:1. Dana 60 rear axle, Moser 1.5 inch 35 spline axles. 4.10:1 Dana gears, ARB air locker, Rear disc brakes with E brake, Long traction bars allow for articulation. Toyota stock front axle with Tru-Trac gear proportional locker, disc brake upgrade with Land Cruiser vented rotors and 4-Runner big caliper disc brakes. Toyota Land Cruiser brake master cylinder and clutch master cylinder. Custom-made National Springs on all 4 corners. Rancho 9000 5-way adjustable shocks. Front and rear sway bars with disconnects. Tires are BF Goodrich 33x12.5x15, Spare is 33x9.50x15. Firestone Ride-Rite air compressor and small tank with pressure regulator to supply ARB locker and to air up tires.
Miscellaneous
Renuel custom made front bumper ¼-inch steel and ½-inch mounting. Warn 8000-pound winch with dash control switch. Hella Rallye 4000 mounted on bumper, right Corning, left Euro driving. Hella fog lights mounted within bumper. Hella twin trumpet air horn mounted under bumper. Renuel rear bumper ¼-inch steel and ½-inch mounting. Custom rock skids to protect body between tires. Stock 16 gallon gas tank and 13.5-gallon gravity flow to main tank under the spare tire. Audiovox Electronic Cruise Control. Hand throttle on transmission shifter. Diamond Liner spray in bed liner.
2001 Four Wheel Pop-Up Ranger Model
Ranger model is 8 foot long and sized for pickups with 17-inch height side bed rails.
Camper features
3-Way Refrigerator. 16,000-BTU forced air furnace. 8-foot Fiamma awning. Side awning and back porch lights. Front sliding window. Deadbolt. Arctic Pack insulated liner. 2 roof vents. Front roof vent Fan-Tastic power vent. Shurflo water pump and faucet. 2 burner stove top with cover. 20 lb. LP gas tank with gauge. 12-gallon water tank. Slide out Queen-sized bed. Hella map lights in upper bed. Storage closet. Cable jacks free standing. Camper battery mounted in truck bed. Electronic interior water and battery meter. Wired LED DC volt meter. 300 watt power inverter. Camper outside bottom wood is well-protected with 3 coats of polyurethane floor enamel.
INQUIRES CALL PATRICK AT 775-720-6490 cell, 775-882-3106 home
PVTRUCK@charter.net MATCHED PAIR FOR $19,000.00
Camper can be sold ONLY if truck is sold first without camper.
Rockcrawler
Yes it is... it is a standard Fourwheel Camper. I haven't seen the truck in person, but have spoken with the owner through various threads on Wander the West. Seems to be a great setup.
Kyle
xander69
