roving1
Hmmm... I put all the 4wd guts back in the front of the Taco. There is some slight CV binding at full droop so I think I'm going to have to drop the front diff, despite most of the internet saying it's not necessary for this amount of lift?. The real bummer is the passenger side CV won't seal up against the dust seal in the knuckle. In fact I can just walk up with it fully assembled and easily pull it out of the splines. The CV boot touches the a arm rivets holding the lower ball joint only on this side as well. I don't think it has anything to do with the lift. I hacked around with all the alignment settings and cycled the a-arm up in its travel range and it barely makes any difference.
So ******? My $300 OEM CV is borked? My suspension is borked even though a few measurements look the same? I am cursed?
I bought the CV's like 4 months ago so I am probably hosed. So I would probably have to order one from the dealer and then return the one I have, or maybe slap in an AutoZone one to see if it fits. But those are known to be way less durable. The driver side seems completely normal.
Or I can buy bullet proof high angle CV's for the low low price of $2,000 a pair.
FML. Modding vehicles is stupid.
Lift is 3" OME with SPC upper A arms.
Previously I had to go through a saga of where the driver side CV kept popping out of a True Trac diff. Eventually it got part of the c clip for the CV stuck in the splines and the CV was stuck in the diff about an inch outboard form its normal position. I had to ship the diff off to get it pressed out and have the diff reworked to not have the CV pop out. But this problem is now on the passenger side and looks like it is seated in the ADD housing normally.
View attachment lo res cv.mp4
