For sale is a set of six (6) 20" x 10" DBL super single beadlock wheels. These wheels were originally used as a custom dually set-up for a newer Chevy 5500. Each wheel has a 8k rating and can easily used as singles.
The "fronts" are DBL 3 piece super singles (aluminum rim, steel center plate, aluminum beadlock) with 8x275 bolt pattern for the C4500/5500 Topick/Kodiak and the newer International/Chevy 4500/5500. The 4 "rears" are DBL 2 piece beadlock singles with standard semi truck 10x285 lug pattern and separate aluminum adapters to fit 8x275.
Lots of options to run these wheels. Easiest would be Topkick/Kodiak or the newer International/Chevy medium duty with 8x275 lug pattern. However, you can also swap out the center plate for the two DBL 3 piece wheels with a 10x225 (Ford F550/Ram 4500/5500). There are also multiple companies like Venum Wheels that make adapters to go from 10x285 (semi truck) to 10x225 (Ford/Ram).
https://venumwheel.com/products/10x225-to-10x285-75-8-to-10-lug-wheel-adapters-billet-aluminum
The previous owner told he put less then 2.5kmi on the wheels before selling his truck. Wheels were moved around his shop for 2 years and have cosmetic scuffs and chips in powder coat but no issues. I was planning to just buy adapters for my Ram 4500 and rotate in the two spares, but my build plans might be changing a bit. Various spare o-rings, lugs, valve stems, etc included.
Any questions please PM me as I'm not on EP much. I have mounted and dismounted multiple sets of DBL 3 piece wheels and I am happy to answer any questions. I may be able to help with delivery around the Mountain West and AZ for fuel costs. I can palletize the wheels if a serious buyer wants to set up LTL freight.
This is the dually set-up but on a Ford
Wheels are located in South Denver
$3,000
$3,000
