Detachable/removable winch plates
Ga Yota 4x4
Can someone point me in the right direction on where I can purchase or fab a winch plate that I can remove from my jeep? I'd like to be able to move the winch from front to rear depending on the situation. I've also have a car hauler that I'd like to use it on, so I don't want to attach it to the jeep permanently. Any info is greatly appreciated!
Thanks
RoundOut
Try the Warn Multi-mount
Here is a picture of what I think you want. It is a multi-mount system that fits in a hitch receiver. It is Warn part number 75330. I don't know for sure, but I bet Sierra Expeditions could get it for you.
You need a receiver in the front & back and then your winch goes in the carrier. You will also need electrical fittings in the front and back. Warn sells a kit for that, too. You could probably wire your own up much cheaper, though, using just the quick connect fittings and some battery or welding cable.
HenryJ
Mine is a Hidden Hitch brand mount.
Hidden Front Receiver Hitch & Raised Rear Hitch
Ga Yota 4x4
Thanks! These are exactly the ideas I was looking for. I'm leaning towards fabricating my own (enjoy doing stuff like that), but wouldn't rule out purchasing one.
flyingwil
Yup. On a side not to fab one up yourself, just about all fabrication shops have winch mounts available.
Willman
Do you have a stock front bumper or custom?
I loved my portable winch!
It was nice to have the option to winch from ether side of the rig!
I had a Warn system with a 9000 pound winch......get setup!
Ga Yota 4x4
I've got a stock bumper (for now)
+1 on winching from either side. Been 4-wheeling in clear cuts where if you get stuck there’s not be a place to winch to with a permanent mount.
Houie
