There are a lot of choices when it comes to what type of damping you want in your shocks so we put together an article which explains the pros and cons of each, and explains the technical details behind each.
Article: The Pro's and Con's of Digressive, Linear, & Progressive valving, and how each one works.
When it comes to OEM fitment shocks Fox and King have linear pistons with fairly progressive damping curves while Icon and Bilstein use digressive pistons and digressive damping curves.
This article is fairly generic and I'm happy to answer any specific questions you may have.
