Lucky me the Check Engine Soon light came on this morning! :Wow1:
I stopped at AutoZone and they pulled the codes for me. I then checked online to translate them. Here is what I found:
P0154
O2 sensor circuit no activity detected (bank 2, sensor 1)
Front sensor RH bank open circuit
P0155
O2 sensor heater circuit malfunction (bank 2, sensor 1)
Front sensor heater RH bank - short/open circuit
P0300
Random/multiple cylinder excess emissions detected. Excess emissions detected on more than one cylinder
P0302
Cylinder 2 misfire detected. Injector 2 excess emissions/catalyst damaging level of misfire
P0304
Cylinder 4 misfire detected. Injector 4 excess emissions/catalyst damaging level of misfire
P0306
Cylinder 6 misfire detected. Injector 6 excess emissions/catalyst damaging level of misfire
P0308
Cylinder 8 misfire detected. Injector 8 excess emissions/catalyst damaging level of misfire
P1300
Random/multiple cylinder misfire detected. Catalyst damaging level of misfire on more than one cylinder
From what I can tell the most significant code is the P0154 indicating a bad RH Front O2 Sensor. I think all the other codes are secondary problems resulting from the bad sensor, but tell me if I am wrong.
A bit of history:
About three months ago I noticed a change in the pitch of the engine's sound. Very subtle, so subtle I thought I was hearing things. The noice is an airy sound, very difficult to describe, a higher pitch than normal. I thought little of it but then noticed once that it went away and then came back after starting and stopping the engine. Meanwhile the engine ran just fine with good power and normal mpg.
About a week after that the Check Engine Light came on. I never pulled the codes but after it was on for about two days it went away.
Then about a month ago I did a 1200+ mile trip with no issues until the end. I was on a dirt two-track in the rain bouncing around a bit with lots of water splash from the trail's puddles, 5-10mph the whole time. After about an hour the Check Engine Light (CEL) came on, started flashing and the engine stumbled. The CEL eventually went solid. I was able to turn the engine off and on with no issue, a little stumble right when I turned it back on but then smooth running. I drove home 400+ miles at highway speed with the CEL on but no other issues.
The next day I had the codes read, 9 total, and they had to do with O2 sensor. The codes were not cleared with the code reader but by the end of the day they had cleared themselves and the CEL went off.
Three weeks later now the CEL is back on with the codes shown above. There is no stumble in the engine but the MPG is down a bit from normal.
--- So -- Any recommendations?
Replace the O2 Sensor?
Replace more than one O2 Sensor?
Try to clean the connections first?
Other?
Thanks
Brian
P0154
P0155
P0300
P0302
P0304
P0306
P0308
P1300
A bit of history:
Other?
Thanks
Brian
