Discovery 2 Fully Built-Price update 9.5k
Charlesp461
It's time to sell my 2003 Disco, I have loved this Vehicle and out a lot of time and effort into it, but after quite a few trips it has become apparent that with a growing family I need the more room that a truck can offer for what we are doing. this vehicle has been used, it is in good condition, but does have some exterior dents and digs. the interior is in really good condition though, does have the sagging headliner, I never got around to fixing that, it isn't too bad.
This Disco will go anywhere, it is built with Heavy Duty Drive line / Suspension / full lockers / 2004 cdl Transfer case
No oil drips, one of the few discos that can claim that, I park it in my driveway with no marks.
I have owned this vehicle for a couple years, but the majority of the build was done be the previous owner and you can see it all here.
This is the Build Thread for it from the previous owner
http://www.expeditionportal.com/forum/threads/93988-A-03-Disco-II-Build
Here is a list of all the mods/work and pictures
Year: 2003
Make: Land Rover
Model: Discovery II SE
Color: Icelandic Blue (one of 200 brought into the US from My understanding)
Mileage: Aprox 139K
Price: 9500
DriveTrain:
Ashcroft HD Rear Axles (5 Year Warranty)
Ashcroft HD Front Half Shafts and CV's (5 Year Warranty)
Ashcroft Air Locker Front and Rear
Ashcroft HD 4.37 Ring and Pinion Front and Rear
Front Custom Double Cardan Tom Woods Driveshaft w/ Greaseable U Joints
Rear Custom Double Cardan Tom Woods Driveshaft w/ Greaseable U Joints (Replaced Rear Diff Attachment From Rubber Bushing to U Joint)
2004 Transfer case with Center Diff Lock
BritParts Brass Drain Bolts for Front and Rear Diffs
Exterior:
Front Custom Built Bumper w/ Skid, Winch Fairlead, Winch Mounting Plate, and Recovery Points
Rear Custom Built Bumper w/ Hitch, Bike Rack Mount, Swing Out For Full Size Spare and Two 5 Gallon Jerry Cans
Voyager Roof Rack Overland Edition (Removeable rear bar for Roof Top Tent, Limb Riser Tabs, Rear Light Mount)
4 Hella 4000 Lights Mounted On Rack
2 Hella 700 Lights Mounted On front Bumper
1 LED Work Light in Rear
Flexi Flare Fender Flares Cut to Fit 35" Tires
Black Out Hood Kit ( For Top light Reflection)
Trimmed Exhaust and Removed Rear Muffler
Snorkel
Rigid Ignite Flush Mount Backup Lights
Interior:
Full Black Leather Interior
Heated Seats
Heated Windscreen
Custom Built Rear Cubby/ Platform System
12V Power Ran to Rear for Fridge (Not Keyed)
ARB Air Compressor In Rear Side Compartment For Lockers and Airing up
Garmin GPS
Ultra Gauge
Pioneer double Din Stereo with Carplay and Backup Camera
Weathertech floor mats
New Leather boots for transfer case shifter and e-brake
Suspension:
Rover Tyme 4" Lift
Fox 10" Front
Fox 12'' Remote Reservoir Rear
Fox Steering Stabilizer
Lucky 8 Quick Disconnect Front Sway Bar
Removed Rear Sway Bar
Extended ABS lines
Extended Stainless Steel Brake Lines
HD Terrafirma Steering Rods
Wheels:
315/75 R16 Cooper STT Pro Tires with only 1000miles on them
16" Steel Rims
Engine :
Dual Battery System With Battery Isolator
Blue sea Fuse Block
Red Top Optima Battery For Starting
Blue Top Deep Cycle Optima For Accessories
Repairs Made:
ABS 3 Amigos Fixed
All New coolant System(Vicious Clutch Fan, Radiator, Lines, Tank, Cap, 180 Deg T-stat etc..)
All New Vacuum Lines
New Brake Booster
New water pump
New Belt
Top End Rebuilt
Transmission Service
Replaced SAI Pump
New Locks (All Doors Unlock With Clicker)
New Upgrade door lock pin
New Key Fob
New Spark Plugs
New Spark Plug Wires
New Coil Packs
New Valve Cover Gaskets
New Front Axle Seals
New Brake Reservoir
New Front Drivers Side Hub
All New Fluids (tranny, diffs F&R, Transfer Case, Coolant, Brake, Power Steering) in last year, oil in the last month
Just Greased all Steering / Driveline Zerk fittings
Replace Brake Light Switch
Recent Alignment
New Air Filter
New Transmission Filter
New Alternator
New Pasenger Side Window Regulator
New ball joints
and many more that I cant remember off the top of my head
Spare Parts:
Stock Axles
Stock Diffs and Gears
Cargo Cover
Extra Belt
Extra Fluids
Extra Small Parts and Random Odds and Ends
Extra airbag
I am asking 9500, but I am open to negotiation and offers.
Craigslist ad can be seen here
https://portland.craigslist.org/wsc/cto/d/2003-land-rover-discovery-2/6721174766.html
Yeah, it has been a very fun vehicle to own, lots of good places to take it in the northwest and there are very few places it can’t go
Jlbeats
