Does anyone know for sure if the D5 and L405 wheels fit on a 2016 LR4? From what I’m seeing they do and the offset looks similar if not identical, but I’d like to verify. Thanks
Check here: https://disco5.co.uk/forum . I've seen some say they can mount LR4 18" wheels on the Disco but they have to take the brake shield/resonator off - the rotors are larger on the D5. So going the other way with 19" or 20" wheels should work. 18" wheels aren't available on the D5.
I love it! It replaced my 2010 VW Touareg TDI, which was also a beast offroad, but this is like that times ten. 20K miles of flawless operation so far, with some serious offroading in the Rockies and a couple cross-country highway cruises under its wheels. Upgraded the ******tty OEM Goodyear road tires to a set of 275/55-20 Cooper Discoverer AT3's. Decent tire, but I may go for a set of Kevlar-sidewalled AT's next for the added resilience given the limited sidewall you get on the 20" wheels. I'll also eventually get a HitchGate to hold tools, Rotopax, and a second full-size spare, and keeping my eye on the Lucky8 low-profile winch they're developing for the D5 - maybe once the factory warranty is up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
