DIY "No Welding" Roof Rack
Reconnoiter
Can't find a roof rack that does exactly what you'd like? Want to build your own, but don't have a welder? Or, you can weld steel, but it's too heavy? I found a solution. 3/4" (ID) Schedule 40 (thick wall) Aluminum Speed-Rail. If you can use Tinker Toys, you can not only build your own rack, but you can change/add-on/redesign anytime you want. All you need is a Sawzall (or angle grinder or chop saw) & a 3/16" allen wrench!!!
http://www.hollaender.com/?page=sliponfittings
I also used 1" Square Tube (1/16th wall) as a "Floor".
I work as a Rigger in the Film Industry. We build stuff out of the 1 1/2" version on this stuff all the time.
Examples: http://www.all-in-one-truck.com/rigging.htm
If you want to build your own, feel free to contact me, if you have any questions.
Zeiderman
Now that's awesome, how long have you had it on? Payload? Cost of your rack? Last one, how did you connect it to your roof?
Sent from my SM-T230NU using Tapatalk
Reconnoiter
I don't put more than 100lbs up there, but that's because of the "Tip" factor. It could easily handle double that.
tommudd
So how much would a similar rack cost material wise?
Looking at the fittings seems pretty expensive by the time you buy them all??
Reconnoiter
I built it several years ago, but it was much shorter. I recently replaced the vertical pieces with longer ones, so I could add the Hi-Lift, shovel, and axe. It will hold more than you should carry up that high. I attached it with "L" brackets screwed into the factory rails.
Reconnoiter
It's not cheap for sure. I've got over $400 in mine. I did it because it's exactly what I wanted and I can change it easily. My next upgrade is to put four 9" LED flood lights on the front. I can add a cage around the lights for around $100. I can also easily add supports to carry a canoe, or a couple kayaks.The options are endless. You can even build a ladder, to get up there, out of the same stuff.
dshirt
Does anyone have experience with Esto Connectors. I built a platform for the cargo area of my series 80 using 1"square aluminum tubing and esto connectors. Covered with 5/8 plywood and carpet. Have 14" high by width of the cargo area of storage away from prying eyes. Bought tubing pre cut for $60 and connectors cost $40. Took 20 minutes to construct frame.
Now would this work for a full size rack (7 foot) rack maybe using 1 1/2" tubing and the connectors. Would need aluminum gutter mounts which I could probably fabricate. Would it hold enough weight so that one could sleep on it in a tent cot. I have posted this to their company website.
YaRiteZ71
