MLu
Let me start off with saying that I now understand why most roof racks are made out of tubes, not square stuff. This is less of a build thread and more of a practical lesson in aerodynamics.
A bit of background; I decided to try and see if I could modify my Thule roof bars to be a bit more all-round usable and more roof rack like, while still leaving the ability to carry various home renovation related things on there. Long pieces of wood and the like. Working in our apartment building's garage limits my ability to do... well, anything other than the odd hole or cut. No fabrication, no welding. Bolts and nyloc-nuts is what we're going for.
I figured some aluminium L-profile bars would be just the ticket to get a base to work from. From there, the plan is to attach some more bars in between, maybe some sand ladder holders and places for a shovel and a couple of pelican cases.
Said and done - an absolutely never-ending amount of measuring and fitting and fiddling around later, and I have some 4x4 cm L-shape aluminium for sides, and 3x3 cm for the front and back. It feels really sturdy. Not walk-on-it sturdy, but sturdy enough that any weight I'm comfortable with carrying on the roof will have no problem. To get the load to spread evenly between the Thule bars and the first and last L-shaped piece, I figure to invert the front and rear piece. That turned out to be a mistake.
(All pictures are before turning the front bar over, but you can figure it out)
The front bar sounded like a helicopter taking off when driving about 75 km/h and up. Didn't shake and rattle one bit, it just created an enormous noise and an equally enormous wind resistance. The Disco has the aerodynamic features of a brick, but with this thing on it felt like I was towing a parachute. Lesson learned. I took the front piece off and turned it around so that it's now a regular box shape in the front. Still makes a bit of noise, but it no longer feels like a parachute. However; it wobbles and shakes in a really bad way.
As you may or may not see from the pictures, the front bar is almost 30cm above the roof, and roughly at the front edge of the sunroof. My theory, based on absolutely no understanding of aerodynamics (if I had that, I probably wouldn't be driving a Land Rover), is that the air being pushed up by the windscreen hits the front bar and causes the wobble.
Next plan is to try moving it back a bit towards the front Thule bar and see what that does. Anyone else with similar experiences from trying to cook up a roof rack?
EDIT: Yup, that was exactly what it was. Moving the front piece back a bit takes it out of the airstream coming over the bonnet and up the windshield.
