Does anyone have spider gears laying around?
xcmountain80
I need help finding a rear carrier set up (the portion you remove when upgrading to a locker or LSD. I need the spider gears and other parts to rebuild a unit I already have. If you have an entire 3rd laying around that wouldn’t be bad either. This is for a 2006 Tacoma, but applicable years and models range from T100: 1993 - 1998 (Rear) Tacoma: 1993 - 2007 (Rear) Tundra: 1995 - 2001 (Rear) and Sequoia: (2001 - 2006). The sooner the better as I hope to verify whether the issue we are having is in the differential or transmission. I have a rear third with roasted spider gears so I really only the bits and pieces but let me know.
Aaron
Mr. Leary
Glamping Excursionaire
Got my open carrier from my 4runner. If that will fit, you are welcome to it. Just pay shipping! :)
dyogim
Just an FYI, the tundra compatibility is 2000-2006. I believe there was some that started production in 99 but, definitely not prior.
In anycase, I have an open carrier if you need that. I'll have to look for the spider gears and thrust washers.
xcmountain80
I'm fairly certain the 4runner rear won't work unless it's a 4th gen and even then maybe not. Open Is fine as I'm trying to diagnose an issue and have a extra 3rd just blown spiders.
shawkins
You need a 8.4" carrier. All 3rd gens have 8.0" diffs. 4th gens might have 8.4" diffs?
Its too bad, I have a extra 8.0" carrier you could have, and it would fit in a $9 USPS Priority Mail flat rate box!
BLKNBLU
Try e mailing ZUK. He does so many installs and re gears, he has lots of left over parts around. I'll bet he has some.
http://www.gearinstalls.com/
e mail link at the bottom of the page
...and don't mind the "gone fishin" notice. I think it just means he isn't doing diffs til it cools off, not that he is gone entirely.
stone23
