Does anyone make an enclosed (like Wells Cargo,Carson, Pace...) that has a single HD axel and larger wheels/tires
marty.clear
I'm just looking for a smaller (5 by 8ish) enclosed trailer that has a heavier duty suspension. This would be setup for utility and periodic trips to carry gear that will keep the water and dust out. It seems silly to buy a trailer and then replace the axel/wheels/brakes.
Thanks
Marty
Ozarker
Define "heavy duty" suspension. Cargo trailers are pretty much built for hauling the most common cargo, household goods, machines, tools, etc. Expected weight to be carried in such a small trailer doesn't warrant a "HD" suspension.
I suggest you just find a local cargo trailer manufacture and order what you want. Might consider something a bit bigger too, I wouldn't go smaller than a 6X10 to 6x14 Vnose. More useful and will hold their value.
A 5x8 will be limited, not only by weight but as to useable space. Doubt you find a 5X8 with standing headroom.
And, when it's time to sell that trailer I doubt you'd have much demand for it.
Which brings me to the least expensive way to get one, find a used one and change the axel yourself. Just know it won't be worth much more.
eatSleepWoof
Do it for the 'gram
I had a new axle installed (part of a lift) on my last trailer and it was about $1250 CAD all said and done. Not a huge expense, relatively speaking. The current 6x12 cargo conversion I'm working on will almost certainly come in at over the axle weight rating, so I'll be swapping that axle for a 5000lb one, too. Buy whatever trailer you want, then get whatever axle you want; it'll be cheaper than looking for the perfect setup from the get-go.
Houie
