redraif
The uphill battle begins
2001 Montero Sport XLS 3.0L Automatic 4wd...I'm at 245,000 now.
Posted at monterosportonline forums about the repair a friend did as well the harmonic balancer/crank pulley replacement, but no reply. So maybe you guys have some advise...
So here is Harmonic balancer issue I had at the tail end of July...http://msport97.proboards.com/thread/10907/opinions-sports-harmonic-balancer-repair
History: The timing belt was replaced at a shop not terribly long ago. 15,000-20,000 ago, but the o-ring behind water pump failed and it was replaced 2500 miles ago at the same shop (different tech). I believe the Harmonic Balancer had to come off for the water pump to be removed and this is wear the issue occurred. Tech did not torque harmonic balancer/crank pulley bolt back enough (he has since been fired btw...)
Long story shortish...
Not sure I trust the story of the emergency repair my friend did on the sport after the pulley backed off and I'm getting annoyed with him. I'm still in learning mode on the sport & these foreign motors, but there are some holes in his account of what he fixed.
I'm beginning to think it was just a simple case of the bolt backing out and he simply ran it back in. But I think he is embellishing to get more praise, as he keeps adding to the story. I'm a girl and you know how some guys are... The night of, it was towed to my buddies house. He said the HB bolt backed out, sheared off the key way on the balancer (woodruff key?) not the crank pin, and bent the timing cover a little. He says he made a new key way from scratch, cleaned up the spline and fixed the timing cover housing with a ball pin hammer. He said it looked like someone originally ran in the harmonic balancer/crank pulley bolt with the wrong socket size and might have assumed they torqued it enough but did not. He said he definitely torqued it down enough when he put it back on. He said probably too much. I said 135ft lbs and he said definitely more then that. Will this cause an issue? I started it up and the bolt looks steady and solid. Motor sounds good. No wobble from the harmonic balancer/crank pulley.
I asked about what things looked like when he took it apart. He said one of the tensioners would not release and he had to walk on the belt. Not sure which one he is referring too. From a youtube video I saw, the tensioners are not as straight forward as the domestics I'm familiar with, so maybe he did not know the procedure. Again it was in the shop 2500 miles ago... if they could have milked me for a bad tensioner they would have, so maybe he just didn't know this motor well enough.... Also he stated the lower gear was rusty and should be replaced. How if the timing belt is constantly riding on it??? Is this even something that is serviced and replaced on less a tooth breaks or chips? What really raised my spidey senses was when he said the sport had a timing chain. Ummm no! I verified this is what he meant to say... So I knew immediately he did not take it all the way down to the timing belt like he led me to believe.
So I started doubting the extent of the repairs... I researching the repair online. In other applications people have had to make new (woodruff keys?). That is not catastrophic. Is there one on the sport and where exactly does it ride? Where is a picture of one on our engines? Would the balancer backing off like mine did (above pic), shear the key? Is there a woodruff key or whatever the name is? Can I get the correct replacement one from the dealer? He says he made a keyway out of carbide steel. I hear that and think, End of a drill bit maybe??? Other people have had harmonic balancer/crank pulley Bolts back out and been tightened back down to proper specs and have been fine as long as they are torqued right. No mention of shearing keyways.
Another question, is the timing cover bending when the bolt backs out and the pulley starts to fall off? Is there one timing cover or two. The video I saw has me thinking there is a lower one around the harmonic balancer/crank pulley area. Is this one bendable? I keep researching and looking for an exploded diagram of the 3.0L and having no luck. Can anybody point me to a good diagram of the exploded motor parts with the names labeled?
Now because of this failure, I want to replace the harmonic balancer/crank pulley bolt and washer to be sure I have the Mitsu updated version... this is a no brainer... and I will get it done 100% (already talked to the shop that fixed the water pump 2500 miles before the HB bolt came out... they agreed they are liable for the bolt backing out and said they would replace the bolt and balancer for me for free if I brought in the Mitsu one. Tech who did my repair was fired... hmmm... bet I know why)
Now the question is about the harmonic balancer/crank pulley itself... I was thinking about swapping it for good measure. Its probably original. I was figuring it would be about $100.00. I about fell out of my chair when I saw this price... $257.44
http://mitsubishiparts.net/parts/20...leid=202711&diagram=F709060&diagramCallOut=32
Ok with a bad catalytic convertor that still needs to be replaced, this is a bit out of budget... gulp...
Can I go with one from the parts store? $109.99
http://shop.advanceautoparts.com/p/...assembly-594-056/15950102-P?searchTerm=pulley
http://www.oreillyauto.com/site/c/d...=Search_02316_1440850_1385&pt=02316&ppt=C0332
http://www.autozone.com/external-en.../2001/6-cylinders-h-3-0l-mfi/309466_172580_0/
Or... Can I continue with my current one and inspect the rubber to be sure its ok? What do I look for? Is there a way to paint a line on it to show if there is excessive play in the 2 halves indicating the balancer rubber is on its way out. I bought this with 225,000 on it and I don't know if this is original or not.
Thanks for your thoughts and advise...
