Dometic CFX Fridge Issue, Need Advice
emyers
I've got a Dometic CFX65 fridge that is experiencing temperature control problems and I need some expert advice. I thought the thermistor was the issue because they're known failing and ordered a new one. It was reading really high and the compressor would never turn off. While dissembling the unit I noticed some corrosion around the compressor fittings and would love some opinions on whether or not the corrosion could be the problem or if this will turn into a bigger issue over time.
Superduty
Was the thermistor the problem?
That corrosion doesn't look great. You might try cleaning it up with some Scotch-Brite to get rid of that corrosion and then check back on it in a few months.
Is it still under warranty?
Sent from my SM-G973U using Tapatalk
broncot
This is a forum for selling items, might want to move the thread to get more attention.
Sent from my BBE100-5 using Tapatalk
