WEEBOB
93 4 runner,looks to have rear 3" spring lift,front seems to be max lift/tor.bars, when you get it in a drivers side high twist the drive shaft hits the gas tank.it has an extension on the panhard bar bracket, has anyone had this problem and what is the cure? When you get it in a passenger side high twist the shaft is 4-5" from the tank,that seems to be a lot of side ways movement for the shaft for this small car. This is not my car but was brought to me with the problem,i'll make it work right but what is the proper fix??????,
