DT ProFab diff covers for Dodge 11.5 and 10.5 AAM axles.
crawler#976
Had the opportunity to get a prototype diff cover from David at DT ProFab. It's made from 1/4" laser cut plate, bent to shape, TIG welded to a 3/8" flange, and then ground on a flywheel grinder. This one is powder coated - not sure if the production models will be, or if you will have a choice of coated or raw steel. The added depth will increase oil capacity some - not sure exactly how much yet, but when I get the install done, I'll add that info to this post. The covers are also being built for the 11.5" rearend as well. I dont' think they have them on the website yet, but you can e-mail or call them at the shop. http://www.dtprofab.com/
The cover uses a 1/2" NPT for a drain plug, a 3/4" NPT plug for a filler plug. I ordered a 1/2" socket head magnetic plug for the drain, a square head 3/4" magnetic plug for the filler from http://www.magneticdrainplug.com/. The recessed socket plug will prevent it from being turned by an impact on a rock or other trail debris like crossing a downed log. If I'm lucky, the plugs will be here next week so I can get the install done over the New Year break.
And before someone asks,
Is it bullet proof?
No, it's mild steel 0.250 plate w/ a 0.375 thick flange.
Is it a hell of a lot stouter than the OEM cover?
Yes it is.
How much does it cost?
I don't know. :sombrero:
crawler#976
Update:
I had the spare make contact with the cover ar full compression.
DR ProFab has redesigned the cove to clear a 35" tire in the stock location. It's got more slope on the top angle and is a little thinner in depth.
The flange is flywheel ground flat 3/8" steel, shell is 1/4" steel. Fill hole is 3/4" NPT, drain 1/2" NPT. I'm using GotDot magnetic plugs.
There are 5 covers in production as of today - more coming soon. Covers will be sold bare steel - you paint'm, plate'm, or leave it to mother nature to color it for you, just like Dodge does on so many other parts...
As for price and availability, call Dave at DT ProFab 928 776 4129
I used Dupli-color Bcc0419 Flame Red over Dupli-color white primer.
It can dry until Saturday when it gets installed.
flipstick
