Dual battery ideas
91xlt
i use the solenoids also, wired into the ignition circuit. the set up i use is from Painless Wiring it's the MasterMinder series, for a few reasons...1. wires into ignition circuit, so when vehicle is Off the solenoids open thus, the batteries are seperated, when On the solenoid closes and the batteries are joined, for charging and also for power, if any one of the batteries are low, when joined gives enough amps to start rig. 2. this unit is run by a small microprocessor, charges first the main batt, then Aux 1 then Aux 2 and in addition inside the cab is a selector switch unit giving you the choice to use Main only Main and Aux 1, Main and Aux 2 or Emergency which joins all 3 together....Yes i said all 3! i run an Optima red top for Main, for starting ...Aux 1&2 are yellow tops, i use the second mounted underhood for additional other than stock electrics and the Aux 2 mounted in rear of truck for camping equip and Em back-up 3. the Masterminder also gives the option of installing a 110v circuit to plug in when vehicle is sitting for extended times w/o starting, i figure eventually i will add this for extreme cold weather charging if need be.
gcec
We use the solenoid based product produced by National Luna
http://www.nationalluna.com/
Their Dual Battery Management system is easy lo install, has a visual monitor inside the vehicle, features an over-ride when winching, and is able to identify when the user has incorrectly wired the batteries.
They also make a wicked Portable Power Pack - it's a plastic box that holds a battery, solenoid, battery monitor and alarm, and Hella power points. Best part - it's removable. Just unclip two wires, pull it out of your vehicle and pop it on the the table to power devices by the fireside. Or, if your truck is your daily driver you can put the Power Pack in the house when it's not needed.
