Dual battery solar powered...
MOSDIF589
Axel Adventures
Did some searches but needed it spelled out for me as I'm not good with electricity.
I have a 2013 Jeep JKU with a GENESIS dual battery system that I have Optima Yellow top batteries installed. I run my ARB fridge and some small LED lights with it but in the summer time in high heat will run the battery down before my camping weekend is up.
What I want is a solar panel that I can install while parked to charge the auxiliary batteriy / batteries while parked. I've been told that I can get a panel and hook it up to the factory alternator cables so the power will run just like it is coming from the battery and let the dual battery system work as if the batteries are being charged by the alternator.
Does this sound possible?
How would you hook up the panels wiring to charge the battery / batteries?
Maxcustody
I have the same setup.......I had to call Shane (Genesis owner) for clarification when I hooked up my solar plug. He said to charge both batteries, it must be hooked up to the cranking battery...........I have a 90 watt panel from overland solar.
http://overlandsolar.com/collection...oducts/copy-of-3-panel-folding-90w-solar-unit
flipstick
