Hey there,
I am trying to figure out the rest of this diagram so I know what I need to get in terms of Blue sea fuse blocks, fuses, wiring, relays. What needs a relay and what doesn't.
Here are my Wattage and Amp-hr loads. I am not running anything major. The only thing I see that I would run regularly is the fridge and maybe on occasion a laptop.
You can see I am using a dual battery setup with IBS battery controller
The Starter Battery
The 20" light bar I want connected to turn on with my high beams
Back up lights will turn on in reverse.
and Fog light will turn on with fog lights.
The Aux Battery
I want everything running off my aux batt. to have its own rocker switch in the vehicle and likely have its own relay.
The Starter Battery
The Aux Battery
