E350 Fiberglass Top Questions
EarlVanMan
Hello Expedition Campers,
I'm close to pulling the trigger on an 2003 E350 but wanted to get some opinions from the experts here. The van is an accessibility vehicle with a wheel chair lift that I will be removing. My question is about the existing high top. Obviously high tops are nice for camping and moving around inside which is why I chose this vehicle but I'm hoping to put a rack with solar panels on top as well as installing a fan and ideally another small window. I couldn't find much in the forums or the web about installing a rack on a fiberglass top except for a couple mentions about Fiberine. In those instances the builder knew what they had in the fiberglass roof top but in my instance I don't know much, just what I can get from pictures as the van is not local to me. So here's a couple pictures, anybody have any experience putting rack or other installations on a topper such as this one? Thanks in advance and thanks for having me here on a killer forum (first post).
-Earl
01515_l9KNE17SYeyz_0CI0t2_1200x900.jpg 00S0S_5UoHNXhVnKoz_0CI0t2_1200x900.jpg
  • Like
Reactions: WVI
EarlVanMan
Most seem to install racks above the top, with braces coming down to gutter mounted brackets.
Is this what you are describing? Makes sense if there is not enough support in the fiberglass topper. Could also make for a convenient place to mount shovel, awning and other goodies. Thanks!
Bbasso
Expedition goofball
My personal van...
Thule rack used from CL, some aluminum right angle and three 100watt panels.
It's light weight and has been trouble free for 5÷ years.20210329_193204.jpg
EarlVanMan
My personal van...
It's light weight and has been trouble free for 5÷ years.View attachment 651515
Simple and easy enough, did the angles on those racks just end up fitting onto the angle of your topper correctly? The part circled in red:
Also did you install that light and/or ac? Thanks!
Bbasso
Expedition goofball
Faux gutter mounts, a bunch of measurements to get them in place.
I mounted the lights and fan.
All rather easy.
