E4OD advice
mp_tx
I just added a couple items to my E4OD equipped ambo. No problems with it so far, but its very low mileage, so call it preventive maintenance. Added a Banks Trans Command and the Derale "cooling" pan. I bought the Derale pan for several reasons, and the "cooling" tubes were not one of them. Priced well, extra capacity, steel construction, trans temp bung, and drain plug were the factors in play.
cjken
Picked it up.
Nice to have it driving under its own power.
Shifts nicely.
They added an additional cooler.
Should be good to go
cjken
They did put a larger cooler in.
Not sure if it is the 6.0 or just some other aux cooler. It does not look as large as the 6.0 in the picture. I’m am hopeful that it will be good moving forward (and backward)
cjken
