Econoline High Top Leaks - Replacement Weather Stripping?
ian89
Hello all. I have an old 1994 Econoline with a fiberglass high top. It was originally built Intervec as a Falcon 190. I have a few leaks at the rain gutter/high top seal. Does anyone know what the track & weather stripping originally installed is called and/or where to buy a replacement? It looks like an aluminum track screwed to fiberglass with a rubber gasket that seals over top. The weather stripping has shrunk and cracked - I want to remove everything for a proper re-seal. Might leave the aluminum track but I want to replace the rubber part over top. Photo attached. Tried searching online but can't find any specific reference. Any help is appreciated. Thanks,
Cummins_expo
I would pull the white strip and do a once over on every screw- Make sure they haven't wallowed any holes. Chase each screw with a dap of silicone and reapply new trim
ian89
Thanks. Do you have any idea what the white rubber strip is called?
I need to purchase a new rubber strip before starting but I can't figure out what it's called or where to purchase.
Cummins_expo
I posted an amazon link to the white stuff- If you mean the part with the screws its an aluminum channel and not to easy to find- You might be able to get the alum strip from http://fiberine.com/GVMR/Home.html
There are some flexible aluminum screw channel through the marine industry but its $$$$
