Eez-Awn Shower Skirt length?
PCRover
Does anyone know the height of the Eezi-Awn Shower skirt for the 1200 series tents? My Defender with rack is fairly tall and I am wondering if the Skirt would be long enough to reach the ground from the bottom of the tent. I need to use the extension to the standard ladder to get ground contact.
I am also wondering how it attaches to the tent bottom. Does it snap on, use velcro or some other method?
Contact Paul at equipt.com for full answers
The Eezi Awn Shower Skirts are standard at 2 meters in height, or appx. 78.75 inches. We can order them longer, 2.2 meters (86.5") if necessary. Also, they are available in either Beige or Olive.
Cheers,
The Shower Skirt attaches to the bottom of a Series 2 or 3 tent by means of a male/female welt system. There are 4 aluminum extrusions (2 short, 2 long) that screw to the underside of the tent half that hangs out from the truck. The 2 long ones mount along the panel sides from the hinge to the panel corner. The 2 short ones mount from each corner toward the ladder. This builds a perimeter around the bottom of the overhanging panel. There are 3 seperate panels that zip together to create the skirt. At the top of each panel they have created a welt of fabric. That is simply fabric wrapped around a piece of cord. This welt is the male half that slides into the female extrusion mounted on the tent. Each panel then hangs independently, and can be connected with zippers at the corners. There is also some extra material on each side panel to run up the sides of the the vehicle a little ways too. It come with stake loops at the bottom to hold it to the ground securely.
Hope that helps.
Cheers,
It looks like the shower skirts are available on all tents up to 1600 in size. Is this correct? I am looking at the 1800 and would love to get a shower skirt for this model.
It is not something we stock at the moment, but I would think it is available. Send me a note directly and I will be happy to investigate it for you.
Paul@Equipt1.com
Thanks,
Paul
Great description, it answers all my questions. Thanks!
Hope that helps.
Cheers,
The 1800 Shower Skirts are available, as are longer models. The longer ones are 2.2 meters, or 86.5", compaired with the standard model at 2 meters, or 78.75"
I am bringing in a couple of the 1800 skirts with the next order, and can get the longer ones special order. Let me know ASAP if anyone wants a longer one.
Cheers,
Sure. Please contact me directly, so I can get some information from you to let you know when it is in. Once I hear from you, I will go ahead and edit my order.
Cheers,
Bobbyjr
