EEZI AWN Swift Awning Wall Set - $500
brookie0907
Discover the Eezi-Awn Awning Enclosure Collection – an ideal supplement for your current awning. Every single set creates an intimate, secluded area featuring a secure door and one or more windows, offering shelter from the weather, a comfortable space to dine, and ample room to change attire while standing.
Single wall construction, covering 3 sides.
260 gram Teflon coated rip stop material, YKK zippers
Right wall: 84"W x 81"L, 1 Window 44"W x 44"L, 8-1/2" material flap at bottom for ground
Left wall: 84"W x 81"L, No Window, 8-1/2" material flap at bottom for ground
Main wall: 88"W x 81"L, 1 Door 27"W, 8-1/2" material flap at bottom for ground
2 spring loaded pole sets, made up of 3 pieces each, for supporting left and right walls
Main wall utilizes the expansion rod between rafter arms
Total weight: 17 lbs (wall set and bag: 14 lbs, pole set and bag: 3 lbs)
$800- 1000 new, if you find in stock.
Awning not included.
Used once for 2 nights. Just never use it and am trying to thin supplies.
Shipping from 28655.
