Electric Jeep
Hill Bill E.
Oath Keeper
Pretty slick. I know there was a guy on the CJ2A forum doing this to a 2A.
I easily put on more than 30 miles a day, but it's nice to see the technology is coming along, and in a 4WD!!
wADVr
Thats pretty cool, gotta get a conversion price to do the math... a WR250 would cost about $2 per day (30 miles round trip) to commute on...:roost:... funner too. My Dodge is just under $6 per day.:(
jeepdreamer
No-go VaroooM
I don't find the idea of an electric jeep very appealing. From a "green" perspective the idea of recycling batteries is something far in its infancy. And as far as my understanding goes, limited as it may be, Lithium is even more scarce than oil...isn't it? And how does one dispose of it when it is no longer usable as "fuel"??
Add to that the image of a Jeep...mired and slogging through deep mud or fording a stream...how does electricity look then? Sure there will eventually be ways to ensure it will survive (if it doesn't already?) the rigors of off roading but I'm not sold.
Instead...I prefer the idea of a diesel. Bio diesel to be more specific. Its existing technology that gets better day by day. Is almost plug and play. Has a broader enviormental availability and less impact than its fossil fuel siblings...
So how would you get a Jeep thats diesel affordably...?
HPA Jeep TDI Project August 16, 2010
Thank you for subscribing to our Jeep newsletter... Though we are old veterans when it comes to motor swaps and crazy vehicle conversions, the Jeep scene is somewhat of a new one for us and we appreciate your support.
While the step by step build process will be covered by JP magazine, we wanted to offer our loyal readers some insight into the direction this project has taken behind the scenes.
Initial study and conversion:
We started with a 1991 Jeep Wrangler YJ with the 2.5L 4cylinder and AX-5 gearbox as there seems to be no economical rebuild path for the aging power train on this very common package. The (PD) TDI engine we selected weighs in 55lbs lighter than the original 2.5L AMG motor we yanked out, and produces 45 lb-ft more torque that our Jeep would have done in its prime.
With the engine removed, the OEM frame mounts have been detached and our new mounting solution is bolted in. You can choose to either weld or bolt on our mounts, but our test mule will have these bolted on so we can stress test them long term.
We retained all original Jeep geometry from the flywheel back through a crank shaft adapter and bell housing adapter assembly. The OEM Jeep flywheel is modified to match the crank shaft adapter bolt circles allowing you to uses any off the shelf Jeep clutch kit. We have had many satisfied years of working with SPEC for all our high performance Volkswagen/Audi builds and as such have chosen their Stage 3 clutch kit for our Jeep project.
The engine has now been in and out of the Jeep a number of times as we documented and patterned the widgets that have gone into this initial build. It is very exciting to see the cleanly installed assembly as it looks like it could have come that way from the factory.
Our TDI is rated for 100hp and 180 lb-ft of torque stock in its stock form but has even more potential with a few simple performance mods. Because our conversion retains the original engine ECU, a power prom flash can easily be added to bump this to 165hp and 280 lb-ft of torque respectively.
Adding to this package, we have designed our downpipe to mate up with an off the shelf Magnaflow 2.5" exhaust system for the Wrangler. As it happens, 2.5" is the ideal diameter for maximizing the power of the TDI.
We are also exploring a custom cam for our PD motor that will smooth out its idle and adds a proven 12hp gain and 22 lb-ft of torque as a stand alone upgrade (outside any power flash).
Our team is only weeks away from unveiling the finished project, complete with some new goodies for the body and chassis, and we will have pricing available after the Labor Day long weekend.
We will be offering three groupings:
Grouping 1 is a bare bones package targeting the Do-It-Yourselfer. It will include everything required to take a late model TDI motor and physically integrate it with the 4cyl YJ driveline. Our team will supply a list of TDI engine codes that are best suited for this conversion.
As pictured:
- engine mounts
- bell-housing adaptor
- crankshaft adaptor
- Machined flywheel (exchange)
- Downpipe
Grouping 2 will include everything in Grouping 1 and will expand it with our custom air intake solution and an air to water cooling package, along with the coolant line flanges we have designed to retain the OEM Volkswagen cooling system.
Grouping 3 This package will be a little ways off but will include an entire engine assembly with the majority of the electronics prepared for installation; including radiator fan assemblies, etc.
For all three groupings, we will offer an "Immobilizer Defeat" service to those wishing to utilize the original VW wiring harness and ECU as we have done in our project. This will open the door to a variety of TDI power prom upgrades and retains access to factory VW OBD diagnostics.
Once the demo truck has been shot by JP magazine, we will bring in an AX-15 gearbox and start at the adaptor system for it, along with pulling in a 6 cylinder Jeep to verify that our current mount solution will cross over with no issues.
As always, we welcome your feedback... please email us your questions or comments.
Sincerely,
The Team at HPA Motorsports
sales@hpamotorsport.com
604.598.8520
Clemtiger84
