Electrical advice wanted - "House Battery" as dual battery system?
MagicMtnDan
2020 JT Rubicon Launch Edition & 2021 F350 6.7L
2014 Jeep Wrangler JK Unlimited Rubicon
I've run 2.0 AWG wire from my battery to the rear storage area (behind the rear seats) to a Blue Sea 12 circuit fuse block.
I now want to connect a 2nd battery (and AGM battery?) located in the rear and use it as a 2nd (dual) battery. It will move weight to the rear, save me hundreds over the Genesis Dual Battery kit and give me peace of mind having a 2nd battery.
Questions:
1. Is this a good plan? I'll secure the battery so it's not loose.
2. Is an AGM battery the way to go? Is there anything I need to know about using an AGM battery in regard to maintenance, etc?
3. What is the best product to use to combine batteries during charging and isolate the batteries when discharging? I found two options - which of these is best or is there a better option?
https://powerwerx.com/blue-sea-7611-batterylink-charging-relay
or
https://powerwerx.com/blue-sea-7622-auxiliary-battery-separator-500amps
I'm OK with electrical but understand the risks and want to do this right.
Thanks in advance for your input.
Clemtiger84
