Hello everyone,
This is a work in progress. I'm not a pro, but I do consider myself mostly up to date on 12v wiring. Enough not to fry my willy off anyway. Most of the components have been selected and purchased, now its on to where to layout everything, decide on wiring accessories (terminal blocks, panels, fuses) and then the appropriate connectors and wire.
A lot of what I'm doing is overkill (PWM solar would have been fine, batt monitory is not crucial) but whatever, it's fun. This Disco is mostly going to be a weekender for camping and a few extended road trips, but I'm setting the bar more towards a proper expedition vehicle.
Component Layout Mockup (wiring TBD)
Components (and links to where I purchased them)
Most of these have been selected based on general forum consensus.
Batteries: 2x Odyssey 34-PC1500 (have not bought yet, waiting on tray below to estimate fit)
Battery Terminals**: Milspec $25 (https://www.amazon.com/gp/product/B00X36RILW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
Dual Battery Tray: Columbia Overland Land Rover Disco II $200 https://columbiaoverland.squarespac...rover-discovery-2-dual-battery-tray-1999-2002
Dual Battery Isolator: Blue Sea ML-ACR 7622 $175 (http://www.hodgesmarine.com/Blue-Sea-7622-Ml-Series-Heavy-Duty-Automatic-Charg-p/blu7622.htm)
Battery Monitor: Blue Sea M2 1830 $187 (price went up to $225, maybe look elsewhere... http://www.hodgesmarine.com/Blue-Sea-7622-Ml-Series-Heavy-Duty-Automatic-Charg-p/blu7622.htm)
Solar Panel: Solar Cynergy Flexible 120W $119 (https://www.solarblvd.com/product_info.php?products_id=3082)
Solar Controller: MorningStar SunSaver MPPT 15A $213 (https://www.solar-electric.com/mosumpsochco.html)
Solar Monitor: MorningStar Remote Monitor $78 (https://www.solar-electric.com/mormredime.html)
Solar Remote Temperature Probe: MorningStar $25 (https://www.solar-electric.com/prosremtempr.html)
Inverter: Xantrex 600w Prowatt $160 (https://www.amazon.com/Xantrex-806-...d=1481308931&sr=8-4&keywords=xantrex+inverter)
Battery Charger: CTEK Multi US 25000 $217 (price went up, look elsewhere http://www.tunersports.com/ctek-multi-us-25000-56-674_p5950.html)
Fuse Panel (under steering wheel)**: Blue Sea 12 Circuit Switched (https://www.amazon.com/Blue-Sea-Sys...0220&sr=8-1&keywords=blue+sea+fuse+panel&th=1)
Accessories
Fridge: Dometic CFX 65 (https://www.amazon.com/Dometic-CFX-...F8&qid=1481309067&sr=8-1&keywords=dometic+cfx)
Gauges Coolant Temp / Oil Temp / Oil Pressure gauges**: Auber (http://www.auberins.com/index.php?main_page=index&cPath=5_21)
Wiring Components
Relay for switched fuse panel**: 80A Solenoid (https://www.amazon.com/gp/product/B0050I94XG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
80A circuit breaker**: Blue Sea 80A (https://www.amazon.com/gp/product/B005BI5466/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
Power distro block for fuse panel under steering wheel** might replace this due to the screw type connection (https://www.amazon.com/gp/product/B001F6W4FW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
Many more components TBD
Tools
Hydraulic Battery Crimper (https://www.amazon.com/gp/product/B0114QC3OY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
** currently installed in vehicle (previous project)
Some pics of what I've done to date
The Auber gauges were fun. I did 2 add-a-fuses on the factory fuse panel to pull in a switched + circuit for the relay, and for the dimmer (I think I wired it to headlights). I really like the look of the gauges and how well they blend in to the dash. I was not a fan of the bulky, tacky looking round gauges, so I'm glad I found Auber.
Wrapping up my engine rebuild. I had top hat liners put in! Need to put her back in, but its freezing and snowing here in the PNW
Cut and crimped the factory cables in favor of milspec
I hope this build won't just be a documentation of what I do, so please chime in if you have any suggestions, ideas, or improvements.
Accessories
Wiring Components
Tools
