ELT Notice: Termination of 121.5 MHz Beacons
elcoyote
Supporting Sponsor, Overland Certified OC0004
Thought that those with ELT's would want to know about this
FAASafety.gov - General Information 'Termination of 121.5 MHz Beacons for Satellite Alerting is Coming Soon' -- FAASafety.gov -------------------------------------------------------- Termination of 121.5 MHz Beacons for Satellite Alerting is Coming Soon Notice Number: NOTC0981 On 1 February 2009, the International Cospas-Sarsat[1] Organization (U.S. included) will terminate processing of distress signals emitted by 121.5 MHz Emergency Locator Transmitters (ELTs). This means that pilots flying aircraft equipped with 121.5 MHz ELTs after that date will have to depend on pilots of over flying aircraft and or ground stations monitoring 121.5 to hear and report distress alert signals, transmitted from a possible crash site. Why is this happening? Although lives have been saved by 121.5 MHz ELTs, the downside has been their propensity to generate false alerts (approximately 98 percent of all 121.5 MHz alerts are false), and their failure to provide rescue forces with timely and accurate crash location data. Both of which actually delay rescue efforts and have a direct effect on an individual's chance for survival.Rescue forces have to respond to all 121.5 MHz alerts to determine if they are real distress alerts or if they are being generated by an interferer, an inadvertent activation (by the owner) or equipment failure. Is there an alternative? Yes, the Cospas-Sarsat System (U.S. included) has been and will continue processing emergency signals transmitted by 406 MHz ELTs. These 5 Watt digital beacons transmit a much stronger signal, are more accurate, verifiable and traceable to the registered beacon owner (406 MHz ELTs must be registered by the owner in accordance with Federal Communications Commission (FCC) regulation). Registration allows the search and rescue authorities to contact the beacon owner, or his or her designated alternate by telephone to determine if a real emergency exists. Therefore, a simple telephone call often solves a 406 MHz alerts without launching costly and limited search and rescue resources, which would have to be done for a 121.5 MHz alert. For these reasons, the search and rescue community is encouraging aircraft owners to consider retrofit of 406 MHz ELTs or at a minimum, consider the purchase of a handheld 406 MHz Personal Locator Beacon (PLB) which can be carried in the cockpit whil e continuing to maintain a fixed 121.5 MHz ELT mounted in the aircraft's tail. Remember, after February 1, 2009, the world-wide Cospas-Sarsat satellite system will no longer process 121.5 MHz alert signals. Pilots involved in aircraft accidents in remote areas will have to depend on pilots of over flying aircraft and or ground stations to hear emergency ELT distress signals. For further information concerning the termination of 121.5 MHz data processing visit www.sarsat.noaa.gov [1] The Cospas-Sarsat Organization provides a satellite based world-wide monitoring system that detects and locates distress signals transmitted by Emergency Locator Transmitters (ELTs), Emergency Position Indicating Radio Beacons (EPIRBs) and Personal Locator Beacons (PLBs). The system includes space and ground segments which process the signals received from the beacon source and forwards the distress alert data to the appropriate RescueCoordinationCenter for action. Address SARSAT inquiries to: NOAA SARSATNSOF. E/SP34231 SuitlandRoadSuitland, MD 20746 Phone: 301.817.4515Toll free: 888.212.7283Fax: 301.817.4565 You have received this notice from FAASafety.gov because you have selected "General Information" in your preferences on your FAASafety.gov account. Edit your FAASafety.gov preferences by logging in to the URL below: https://www.faasafety.gov/SPANS/preferences.aspx ------------------------------------------------------------------------- Home Page: http://www.FAASafety.gov Email Preferences: http://www.FAASafety.gov/SPANS/preferences.aspx Opt Out: http://www.FAASafety.gov/SPANS/optout.aspx ------------------------------------------------------------------------- Note: Do not reply to this email, as it is an unmonitored alias. Email webmaster@FAASafety.gov for comments or questions. ------------------------------------------------------------------------- Safety is a learned behavior...Learn to be safer at the Learning Center found on FAASafety.gov
flyingwil
Got this in my e-mail the other day... I am still unsure of my thoughts on this with the addition of 1000' seperation.
HMR
Rendezvous Conspiracy
Just stumbled across this thread...
We leave our #3 radio permanently tuned to 121.5 and monitor it throughout every flight. We've reported many ELT's over the years and while 99% probably are false alarms, the air traffic controllers still take them seriously and will investigate. If you activate a 121.5 ELT, especially in the desert southwest, someone WILL hear it.
We upgraded to 406mhz ELT's on both the aircraft and liferafts a few years ago. I attended a short class on the new procedures. It's definately a huge improvement.
Personally, I'd still choose a Satphone over anything else. I've been able to make crystal clear calls when both the VHF and HF radios were out of range.
Goldenbora
