Cole
I have two D5 Coolant heaters for sale for a T1N Sprinter. There are some good threads on the Sprinter-source forum about making these run off an independent switch.,
The first one came out of my 2004 7 day timer van. It has the 2 plugs on it. I took this out for a "F42 water pump short" error code. The heater worked fairly well before this error but it probably has a bad control unit in it. So I would consider this a *parts* unit or one to play with. $200+shipping
The second one I bought just recently on eBay. It only has 1 plug on it. So it was intended for Sprinters without the 7 day timer. Which means it doesn't run off my 7 day timer. It works 99% of the time but has thrown an "overheat F68 flame sensor code" randomly a few times when run all day long. This could easily be set up to run off a switch if you follow the threads here. I just wanted stock 7 day timer functionality without cutting wires so I tracked down another 2 plug unit. I'll take $300+shipping for this one.
Both located in the Denver, Co area.
