Expo Portal Ham Radio Net - 18 Mar 2008 @ 19:00 PDST
crawler#976
... on the Western Reflector node #9251
Topic is: Expo Portal Ham Net - How can we make it better, and get more participants. We'll also discuss changing the net to a monthly meeting.
Please sign up below!
We need others to take the net control spot, and to suggest topics.
Any volunteers?
Mark - KE7IXX
TD64
I'll be there.
I am not ready for net control yet but as soon as I get the hang of all of this I will give it a go!
Gear
Explorer, Overland Certified OC0020
My family will be camping on the beach in Carlsbad, CA. I am going to try and check in from the campsite. :camping:
Justin
KI6MUG
mr r2fj
I'm going to give it a shot tonight. Now that I have a good external antenna my repeater options are much larger. If I can get a good stable IRLP repeater, I'd take net control in the future if necessary.
Russ Chung
I will try to find a node that I can use to connect to the IRLP reflector from Los Angeles (San Fernando Valley). Is there anyone else in the LA area planning to connect or has already made arrangements to use a node?
Russ Chung
I'm sorry I missed the net. I connected to the 9251 reflector shortly after 7pm, but there was no activity, and someone else wanted to use the node.
TD64
I was there, just not able to punch through.
1Leg (Jerry) and I were talking on a repeater and as I went to set it up for the net, someone else took over while I was reviewing the instructions to set it up! I saw that someone had setup another repeater for the net so we moved to that one and I was not able to hit it. (Jerry, thanks for checking me in.)
So, lots of rookie mistakes on my side. I'll get the hang of it with more practice!
Angel?
Mark - KE7IXX
Hey Mark,
I look to rejoin the net as soon as my local node gets back up. The node's owner is doing some upgrades, which has had it down for a while. After that happens, happy to take net control for one of the nets. Thanks again for all you do to keep this net running - it is unique, well done, and deserves to live. And from what I am seeing, the Expo Ham population is growing.
Cheers, Cal
Goldenbora
