expo xj on a budget
olsen_karl
I used to have a '95 XJ with the 5-spd (AX-15) transmission, which wasn't the smoothest-shifting transmission. Best gear oil I ever had in it (best shifts) was Redline MTL -- and I tried a lot of different oils.
DiabloBlanco
Any updates? Another hello from the Houston area! I really liked your EMT roof rack. Thats what i want to build for mine.
corprin
off the wall, but if you are looking for new seating options, the front seats from a WJ bolt right to the XJ rails ;)
IronRoberts73
Sorry for the delay life has been slapping us around quite a bit lately. So far everything is working well I have driven around 3k miles since the overhaul and no real issues. I have it out at my fab shop for a final push on the rear bumper, tube fenders, skids and a paint job.
IronRoberts73
While using it at the ranch for a work truck we have found a couple of weak points. First the axle side rear ujoint decided to give up and shattered the caps. Easily fixed and we were back in action just in time for the front shaft to develop a fairly severe vibration. I found out the double Cardin joint at the transfer case is a bit worn around the centering ball and cup. But I have got a good start on the rear bumper.
