Extended Run Gerry Can - Honda Eu2000i - In Pictures
Rbertalotto
A few brass fitting, an OMC outboard motor fuel hose, a see-through fuel filter, a piece of copper tubing and an Mag-Wheel air fitting with the valve removed...Done!
The only thing that might need explanation is the air fitting. I'm simply using it as a vent when fuel is being drawn out of the Gerry can. Those of you with Honda EU2000i generators most likely know about the ability of these generators to operate from an aux fuel source thereby extending the run time to days if the tank is large enough.
chevyexpotruck
Nice. Looks like it would work great for those that need it.
I use the military Scepter fuel cans and you can buy the same thing from Scepter.
Rbertalotto
Keep your generator dry.....Gerry Can, Ratchet Strap and a golf umbrella. Worked excellent even in a strong wind. I'm going to make a bracket that attaches to the generator.
iStan814
