Filling a TJ with a gas can... getting covered in gas?
alosix
Checking to make sure I'm not 'doing it wrong', though I've done it a bunch of times successfully.
Last month I was running a mix of fast and heavy sweep for the North Nevada Rally in my TJ. In the heat, it was a lot of work/driving for the nearly 16 year old Jeep. (It actually killed a coil near Fernly, NV on my drive up from Sunnyvale, CA leaving me with a bit of time on the side of the road fixing it).
On my way back down to Fernley the next day from some nowhere town way too far north in too much heat I pulled off to the side of the road to throw some gas in the Jeep.
I put the funnel part into the gas filler. Took the can (5 gallon metal blitz) and pushed it down until the spring loaded thing opened. It didn't seem like it wanted to take the gas. I ended up getting splashed pretty good with gas flowing back out of the funnel. Its always been a bit slow initially to take gas out of the can, but this time it pretty much refused to take any.
I massaged the filler lines a bit and after sitting for a few it finally took the gas, but at first it really didn't want to go in.
Wondering if anyone else has had an issue like this and what they did to fix it. Seems like I've got some sort of venting issue while filling the gas tank. Every once in a while when filling at a pump it takes a few tries before the pump will keep going. Not sure if that's related.
Thanks,
Jason
406to417
2005-2006 TJ/LJs seem to have this issue even at the pump but never heard of it on the older ones.
JIMBO
:sombrero: I'm usually in Fernley, if you need a hand, give me a call-
Thanks,
Jason
PM me and I'll give you my phone No., I'm usually there and if not I'm in California, but 90% of the time in Fernley !
:costumed-smiley-007:bike_rider: JIMBO
Rubicon John
My 1997 TJ had an issue like this when it was new. It didn't like gas pumps either. It would cause the pump to continuously click the handle where no gas would enter the fuel tank. I took it to the dealer since it was under warranty and only a few days old. They replaced something between the fuel door and tank (I never did get a complete answer from them about what was wrong). Problem was solved.
