First SAS Impressions
Back from a shake down run in Silverton for the 4th. 2 Front drive shaft bolts were loose and I ended up with a badly damaged U-joint. A number of other small issues to address as well. It is certainly is not quite "Sierras Ready" as Esther put it. Whether this is worth it or not, is dependent on what you do. A SAS is a ridiculously expensive proposition. At one of the most dirt cheap shops on planet earth we managed to blow over 8K. Granted that is a nearly bomb proof SAS, but still, you better be wheeling hot and hard to justify that kind of bling.
Here it goes;
1. On Highway -- More body roll, tippier on turns.(also no more sway bar, but IFS was very stiff). Front feels like its "floating" and takes a lot of getting used to. Rear end can kick out on slow speed turns due to roll. I was doing 80mph on way home, takes some getting used to though. No death wobble or extreme handling issues.
2. Turning Radius -- 3 Foot Ball Fields(oh those mining roads are fun)
3. Steering -- On highway it is much less precise, tends to feel like there is a delay when you turn. Off-Road, wow, MUCH EASIER, turns like butter compared to the bulky IFS.
4. Off-road stability -- About the same
5. Crossing major boulders -- yeh, I know, hard to find in the San Juan's but I found a rock slide to drive over, and truly the Solid Axle took away all the drama. Maybe 3 foot rocks.
6. SAS on Easy trails -- You feel ridiculous with such equipment for sure. I used 4x4 twice, and never locked.
7. Ride -- On road, rougher on big bumps, otherwise about the same. Off-Road, maybe a bit rougher on big bumps, but in general it was not nearly as bad as I feared.
8. Ground Clearance - -Who are we kidding, its **************. No more down hill road grader plow. Just miss the pumpkin and you are all good.
Overall a SAS is probably more negative then positive. It really boils down to is the super high cost and reduced every day ride worth it to you to replace the aging, delicate and break down prone front IFS, while gaining extreme off-road capabilities.
Some on the carnage repairs string. But will work on lots of pictures during this summers carnage. It does look cool. Silverton was crazy as always for the 4th, and we were constantly hearing cat calls and "That is one Bad *** Montero" , "Wow neat Montero" ect. No one even noticed my rig on the trail before. It was crazy.
lordtrunks
camp loser
lloyd i should have seen it but since they put both your tie rod and drag link on hi steer arms that arn't equal to the stock knuckle(which is the lower on those orange reid racing knuckles you have) it messes up whats called ackerman(may have spelled that wrong) the affects of this are super wide turning radius like what you have and a issues with slow speed turning just like what you are feeling its. its an easy fix with your setup just have them move the tie rod to the lower and leave the drag on the passenger hi steer arm this will make your setup a cross over setup it will put the tie rode below the springs but if you use the nice thick rock rods they take abuse well. or switch your hi steer arms out for a pair of artech industries hi steer arms which don't have the inward curl like yours do. and the artechs can be setup to be double sheer too which is a good thing for a guy that is called the abuse master:sombrero:
http://www.artecindustries.com/assets/images/highsteer/d44-hsa-assembly-one.jpg
