Five 32” Mud Terrain tires and 16” rims for Dakota/Durango
Nick02
SOLD
This rim/tire combo will fit on a stock height 4x4 97+ DAKOTA or DURANGO with no to minor trimming, but it may require a torsion bar crank to provide the necessary clearance without rubbing at full off-road articulation/full lock.
Pre 97 4x4 Dakotas need a body lift to fit 32” tires without trimming. 2wd's need an 3" suspension or 3" body lift to fit them. The full size spare will fit in the stock winch spare location without any modification.
6x4.5 bolt pattern fits
91-04 Dodge Dakota
98-03 Dodge Durango
05- on Nissan Frontier, Pathfinder, Xterra (check to make sure it'll clear calipers) I have no clue how they'll fit on Nissans so do some homework to find out.
The rims are for 16" tires, they are crager 16X7 soft 8's with a 6x4.5 lug pattern !!!!NOT 6X5.5!!!!
Rims are less then 10 months old.
The rims have a flat-black paint job on them, not professional, but looks nice.
Structurally they are in brand new condition, no curbing at all or anything!
They come with no centercaps/lugnuts, but can be bought on summit where I originally purchased them. They have been on the truck for 8 months and were shipped from summit when I bought them.
so you get (5) rims in all
(4) rims that are basically new, less then one yr old, flat black.
(1) rim semigloss black paint job
The tires are 265/75/16 BFG KM mud terrains. (31.7" tall) They have around ~22k miles on them; they tend to wear like iron, and are at about 1/2 tread. I bought them brand new!
They are all in great condition and have plenty of life left, NO sidewall or tread punctures, absolutely even wear, rotated every 4k mi. They were on a lifted 2wd.
One tire has a small nail stuck in between one (middle of tread, far away from sidewall) lug, it has been there for about three months and has caused no issue, I doubt it even got through the tire, I have noticed no loss of air and am not worried about it, too lazy to pull it out. The tires have no plugs, and have never been punctured. The tires were manufactured in 2007, no major chunks missing, no rock rash, no sidewall scuffs, mostly street use.
On the current rims, they are all balanced perfectly and have no vibration. Ride great on the street, a bit louder then all terrains.
The spare is a goodyear wrangler TD 265/75/16, it has been well used and has about 10%-5% life left (almost at wear-bars)
It holds air and I consider it to be a good spare, and will make you home, but I would not trust it as a DD.
So you get (5) fullsize matching size/rim tires in all,
(4) BFG KM's
(1) goodyear wrangler TD SPARE, Matching RIM
READY TO BOLT ON AND RUN!!!!
I will sell all four tires and wheels, with the full size spare for $480, PM me if serious..... OR call/text 602-5 FOUR 1 - 6 SEVEN 0 FOUR
Located in Glendale Arizona
