ISB Cruiser
I am in the planning process of my 83 FJ60 project. The donor vehicle is a 2001 1 ton 4x4 ISB powered Ram. My dilemma is now regarding axle and transfer case selection. I am building this to be as bullet proof as possible for heavily loaded back country exploration while still keeping mileage in mind. So, my dilemma is that I am going to run the Dodge 47RE automatic transmission. I would like to retain the stock transfer case and axles. No adapter is currently made but I can buy a shaft to adapt the trans output to the t-case input. I would have to fab an adapter. My other option is Dana 60's and I am not sure I want to go with full width axles. So I can build an adapter or narrow Dana 60's. Or there is the Atlas option which would require modifying the stock rear axle to center diff or swap to a center diff mini truck rear end. The big question is regarding the strength of the stock transfer case and axles. Can they handle the power of the ISB? Any critique or suggestions are welcome.
