Flagstaff SE custom pop up
2016 flagstaff 207 se
Open length is 21’
Closed length is 11’
Dry weight is 2400 pounds
Clear title
Everything works as it should
Price is pretty firm
Changes done in 2021
All new complete tent enclosure and replaced by OEM. Upgraded vinyl to a heave tier grade and the clear glass to dark tint when ordered
4” suspension lift
3 new 33 all terrain tires on jeep wheels including spare
300 watt (3 full panels ) on roof with upgraded controller
2 odyssey AGM xtreme deep cycle batteries
Outdoor hot shower with built in enclosure
Camper plumbed for hot water
Tankless hot water heater with digital controller so never run out of hot water
Upgraded 35 gallon water tank underbelly
Luggage rack with cross bars and lockable rod holders
15k btu ac
King digital tv roof mounted antenna
30” jacks in all corners
Strong arm lift stabilizers ( trailer will it move when set up )
Fusion marine blue tooth stereo with fusion indoor speakers and outdoor speakers on separate zones
All interior switches removed and new digital switch panel installed
Interior completely re done and all dark wood changed to light gray wood grain covering and gray trim
Couch and dinette seats professionally recovered in gray and upgraded marine custom vinyl
Floor done with light gray Seadek marine flooring
20k Btu furnace with digital thermostat
35 amp ac inverter with built in 12v charging
Built in dc system with inverter and dedicated plugs and usb for off grid camping
Awning ( never been used and stays attached to camper )
Electric roof raising system
Electric front jack with built in lighting
Full RGB led lighting under carriage with interior light controller
LED lighting built in to awning bracket that runs full length on roof line
Limitec led light for outdoor lighting
Outdoor side table for rail system
Outdoor propane grill for rail system that runs on the campers built in tanks
12v water pump system with indoor sink, outdoor shower and outdoor hose
New memory foam mattress for not slides in 2022
New fans and lighting modules for each of the beds
Gas/DC/AC 1.7 cu ft built in fridge
3 burner stove inside
Bottom and frame professionally coated with cosmoline
Electrical system re done with blue seas resettable breakers, common bus bars and marine wiring
New CO2 monitors and gas monitors
Inverter has it’s own power switch
Asking $11,999.00. $10k is what was invested on top of the cost of the standard trailer.
PM here or contact is eight three two seven two six five five one three. Located near Houston TX.
Please PM on here or text to 832-726-5513 if you have any questions.
Thanks
Kingsize24
Very nice setup. I looked at a few of those years back, they are well made and tow very easy with the low CG.
GLWS fellow south easterner.
WonaWarrior
