Fleetwood Neon Electrical System Addition
jrtharpe
HELLO! New to the Portal. Tomorrow I'm picking up a gently used 06 Fleetwood Neon to adapt into an overland/off road camper. My question relates to adding an electrical system to the interior. My goal would be a set up that would accommodate shore power, battery power (when boondocking), and eventually maybe a solar charging system. It's my understanding the Neon's didn't come with an on board electrical system (I may be wrong). If not, what's the simplest and affordable way to add a system? Would adding an "OEM" style RV converter charger like you'd find preinstalled in an RV be the best/simplest route or are their other options I should explore. Thanks in advance!
jrtharpe
Interestingly enough, I was looking at the PD4135K from Progressive Dynamics. Looks like it has a built in charger also. Thanks for the advice!
