Fold down table for rear door?
ssssnake529
I'm looking for a panel to replace the stock panel on the inside of the rear door of my 1996 Disco I.
I'd like it to have a drop down table, and preferably be made from aluminum.
Does anyone sell these?
Viggen
Just here...
No way its that much. I got mine from Justin at Lucky 8. Scrounged the garage for an old butcher block and continuous hinge and was able to build a table that works nicely.
Sirocco
One you have the Pre-fabed door card in place making the table is easy. There are infinate ways to hang it and lock it but the basics are the actual shelf and either a continous 'piano' hinge or a couple of normal hinges. I have strung mine up in the past by using webing riveted to the door card and shelf but recently I have bike brake inner cable held with clamps (allows for adjustment should it be needed) it is also locked up by a hinge mostly seen on the tailgates of series vehicles (keep it LR!)
HTH
G
Chazz Layne
Administrator
Just a thought: if I had it to do over, I would buy two of the door panels and use the extra for the flip-down shelf (with the big side facing out). I can't remember where I saw it (somewhere on here likely), but it looks perfect for a camp kitchen.
DexGtr
that is a damn good idea.
benlittle
attachment.php
This is my table. Couldn't live without it.
kitchen grade stainless panel
1/4-20 riv nuts
1/4-20 stainless button cap screws
1/4 black auto trim x 80in
12.25in 10lb pressure gas struts
stainless strut brackets (boat supply store)
stainless piano hinge
rivets
kitchen grade HDPE cutting board
The nobs have 1/4-20 threads which screw through the table into 1/4-20 riv nuts
David Harris
attachment.php
1/4-20 riv nuts
rivets
Very nice.
brushogger
He always has great ideas. I try to steal as many of them as I can! You should check out his roof rack mounting system. Bulletproof!
Clemtiger84
