- Exterior: Silver clearcoat metallic
- Interior: Leather Graphite
- 139,193 Miles
- Colorado Campervan high top, pop top
- Sportsmobile cherry wood interior build out.
- Kenwood stereo w/ Focal speakers
- Safe – under driver's seat
- Sportsmobile Quigley Motors 4x4 Conversion (4-inch lift)
- Dana 60 solid front and rear axles
- ARB front and rear differential lockers
- Air lift front and rear suspension
- ARB twin on board air compressor
- Hellwig upgraded heavy duty rear sway bar.
- Sportsmobile upgraded front sway bar.
- SuperSprings rear leaf springs
- Front Bilstein shocks
- Left & Right front axle U joints.
- Drag link tie rod.
- 5 BFG All Terrain T/A KO2, LT325/80 R20 E2
- American Racing ATX Series 20-inch wheels
- Auto Transmission rebuilt (transmission overhaul kit, solenoid kit, bushing kit, bearing kit, filter, new band roller clutch, sprag servo piston and billet, bottom torque converter)
- New rebuilt transfer case
- New valve cover gaskets
- New glow plugs and controller
- New performance fuel injectors 60 HP gain, flow rate 120cc
- New turbo
- New exhaust manifolds, manifold gaskets, up pipe kit, turbo gaskets
- BD Remote Mount Vacuum Exhaust Brake
- Brakes (New: master cylinder, brake booster, F350 twin piston)
- New alternator and serpentine belt
- New thermostat
- New power steering pump
- 2 new AGM engine batteries with manual individual cutoff switches
- 59-gallon diesel fuel (Transfer Flow Fuel System: dual tanks w/ digital on dashboard readout)
- New fuel pump and filters
- New heater core
- New wiper motor, transmission & arms
- AC system leak check, evac, & charge
- New front Crystal head lamp housing and Hyper LED bulbs
- Auxbeam 8 Gang Switch Panel: centralized control system for auxiliary add on electrical devices.
- Extreme custom steel front bumper with integrated high boy jack and winch mount
- 12,000 lb. Warn winch.
- Aluminess rear bumper with swing outs for spare tire and storage box
- Aluminess deluxe storage box with rails
- Draw Tite, Ultra Frame, Class 4 Trailer Hitch, 41906 (10,000 lbs. GTW)
- Rhino lined.
- Fiamma awning
- 2, Renogy 100-Watt 12 Volt Monocrystalline Solar Panel
- Renogy DC-DC 30A on Board Battery Charger w/ MPPT
- House Battery Capacity Monitor
- 2 AGM deep cycle house batteries
- Blue Sea Safety Hub
- Colorado Campervan high top, pop top (thermozite insulation, electronic lift kit w/ additional hydraulic lift assist, six LED lights on dimmer, USB port)
- Sportsmobile cherry wood interior cabinet build out.
- New Lonseal flooring, moondust color
- Tripp-Lite DC to AC Inverter/Charger
- 54-inch dinette (with 4 seat belts) folds down to additional bed
- 2 burner propane stove
- Microwave
- Norcold 3.6 cu ft, DE0014 12 v refrigerator
- Thetford cassette toilet
- 20-gallon fresh water
- Espar Airtronic D4 interior diesel/electric furnace with high altitude kit
- 22-inch, 12v flat screen TV w/ integral DVD player
- Roof mounted 80/20 Aluminum T-slot rails.
Breckenridge Colorado
Chris 970-333-9758
