MountainHopper
2003 Nissan Xterra SE Supercharged
Overland Built
***FOR SALE***
Asking $8,500 OBO
Xterra Maintenance/Repairs/Upgrades 2017-2018
BONUSES!
Pictures
*NOT INCLUDED: Fox Wing Awning, Rotopax, Hi-Lift Jack, Storage Bins, Accessory Bags on Molle Panels, Dometic Fridge, Rigid Solar Box (or anything not listed in above bullet points)
***Also Important to note: There is some minor cosmetic damage such as “desert pinstripes” and damage right above rear passenger fender. Interior/upholstery in very good condition.
Overland Built
***FOR SALE***
Asking $8,500 OBO
- Extensive work, maintenance and upgrades went in this Xterra transforming from stock into an awesome and very reliable overland/off roading vehicle
- All service history available
- Looking to pair with a great new owner!
- ~ 143k Miles (Average of 10k miles a year)
- Timing Belt, AC Belt, Power Steering Belt (All Engine Belts)
- Fuel Filter
- Spectre Cold Air Intake Filter
- Bilstein 5100 Shocks x4 & Alcan Complete Leaf Packs Upgrade/Replacement in Rear Producing 2” Lift and 350 lbs added support
- Shrockworks Black Powder Coat Rock Sliders, Dimpled Tread Plates
- New Distributor Cap, Rotor & Spark Plug Cables
- Replaced Valve Cover Gaskets
- Relocated & Replaced Knock Sensor
- Fuel Pressure Regulator Replaced
- New Seals on Upper Intake Gaskets for Supercharger
- Replaced PCV Hose, SC By-Pass Valve Vacuum Hose, SC Control Solenoid VAC line and Intake Air Temp Sensor Mount
- Transmission/Transfer Case, Trans Cooler Hose Front & Rear Diff Fluids
- Hankook Dynapro MT RT03 265x70r17 x5
- Powerstop High Performance Brakes/Pads/Rotors in Front & new shoes in Rear drum w/ Brake Fluid Flush Service
- Power Steering Fluid Exchange
- Coolant Flush Service
- Rear Main Seal & Oil Pan Gasket Replacement
- Swayaway Upgraded Front Torsion Bars for 20% Additional weight Support for Bullbar, Winch and 2 in Lift
- Curt Full Sized Roof Rack with Hi-Lift Jack Mount
- ARB Bull Bar w/ Warn 10k Winch w/ Steel Cable
- Nilight: 2 LED Light Bars - 1 42in 240W Curved Spot Flood Combo, 1 25in 162W Flood Spot Combo, 2 18W Flood LED in rear bumper w/ Illuminated Rocker Switch
- Mictuning HD+ 12 Gauge 600W LED Wiring Harness w/ 40 Amp Relay
- 8 Mictuning RGB Rock Crawler Lights via Bluetooth Control
- Bartact Paracord Grab Handles
- HEPS Design Rear Window Molle Inserts
- TAC TLG Tail Light Cover Guards
- Kenwood Receiver and Mono Amp for Sub Hookup
- Esky 180 Degree Full Color Backup Camera
- 3/16” Vinyl Coated Limb Risers, 920 lb Breaking Strength
- 2 in Shackle Hitch Receiver
- Hitch Receiver Tire Mount
- Cobra 29 LX 40 Channel CB Radio w/ 5ft FireStik Tunable Tip
BONUSES!
- ALSO - Comes with Full set of 265/65R-17 Kumho All Terrian Road Venture AT51 SL Tires (Less than 1k) and 2 other Spares
- Custom built 2 drawer utility system for rear deck w/ slide out wood tray for gas stove
Pictures
